How to open board files provided by xilinx website?
I downloaded the board files in xilinx as follows:
rdf0174-zc702-schematic-source-rev1-1.zip
the address is 'http://www.xilinx.com/products/boards-and-kits/ek-z7-zc702-g.html#documentation'
The contents of .ZIP file are showed in the above picture.
However,how to use them? Which APP I could use to open them?
@lzq8901 You need DXdesigner tool from mentor.
-Pratham
Professor
Professor
It looks like ViewDraw schematics.  Formerly ViewLogic, now Mentor Graphics.  I think the newer versions are called DXdesigner.  In any case if you don't want to edit the files, just view them, generally you can find a .pdf of the schematics in the same place where you found the .zip file.
[Edit]  Had to search a bit but found PDF here:
http://www.xilinx.com/support/documentation/boards_and_kits/zc702_alt_power_schematics.pdf
-- Gabor
-Pratham
thank you
which app can open it ?I want to edit the sch.
