I/O voltage levels of FMC pins in VC707
I am trying to use the FMC pins on the VC707 board for I/O and powering my custom chip. My chip requires about 50+ I/O signals (3.3V) and two power pins (1.2V and 3.3V). I was thinking to use the VCC3V3 power pin and the adjustable VADJ as the two power pins. From the documentation and other posts, I understand that I will need to program the TI controller to adjust the VADJ to 1.2V.
However, my question is, how should I set the I/O pins to 3.3V signals. The datasheet and various other posts say that it is fixed at 1.8V logic (LVCMOS18 I/O standard as mentioned in the datasheet). Is there a way to make these I/O pins at 3.3V? Which rail in the FPGA needs to be set up to make these I/O pins to 3.3V?
Instead of 3.3V, I think my chip can also work with 2.5V. Any help is greatly appreciated!
Thanks!
Re: I/O voltage levels of FMC pins in VC707
Hi @agrawa64 ,
HP Banks can take max VCC of 1.8V, and HP Bank of FPGA are routed to FMC. Hence you cannot give more than 1.8V as VCC ( VADJ Voltage) to FMC Bank.
Hence VADJ Max value is 1.8V VCC.
Since VADJ is 1.8V (Max value), you cannot generate 3.3V/2.5V ( or greater than 1.8V) IO Signal from FMC Banks.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
