Observer kos8108
I found another fmc cable for the qualification comparison! is that possible?
9 " FMC To FMC Cable "
I realize that the cable above is available.
Can I ask you one more question?
I found another product for the qualification comparison. Is this also compatible?
HDR-169468-01
https://www.digikey.com/product-detail/en/samtec-inc/HDR-169468-01/SAM9477-ND/6678214
Re: I found another fmc cable for the qualification comparison! is that possible?
Get a data sheet/schematic for the cable.  Does it connect the power supply from one board to the power supply on the other?  If so, don't buy the cable.  It will likely let the smoke out of something.
Visitor sthotakura
1.You can not use that because it is having  ASP-134486-01[Female] on one of the side and on another side ASP_134488-01(Male connector) this is fine to mate with either ZCU102 and VCU108 boards.
2.The problem is with ASP-134486-01(Female) connector is same which is on both the boards[VCU118 and ZCU102]we can not mate(Female and Female) this connector to any one of above-mentioned boards.
Note:
This type of cables is useful whenever you require one female and one male FMC requirements.
