I tried to send a packet from ML405 via Tri-mode ethernet...
I tried to send a packet from ML405 via Tri-mode ethernet (Temac) configured scatter-gather
The examples supplied with EDK implement scatter-gather using interrupts.
How can I poll the status of the DMA to know it is done (without interrupts) ?
When I sent a frame I saw nothing on an ethernet sniffer.
Should I change some DIP switches from factory setting ?
I tried to send packets with Emac on this board and it worked fine.
I connected the Ethernet cable to the RJ45 socket. The RX, DUP LEDs are on all the time.
