Newbie rodrigo.mmz
IP Integrator XADC + DA3 Modules
Im working on the following IP Integrator design. I have an Arty7 35T FPGA
I want to create a block diagram with two modules. The objetive for this implementation is to create a Analog-Digital-Analog vivado project (This one will be a part for a big project). The modules are:
 - XADC: Input 0-3.33v  converted to 16bits. This one as a clock input ( CLK100MHZ )
 - Pmod DA3: Digital to Analog converter with SPI Protocol. Inputs 16bits is converted by SPI protocol in a Analog value (max 2.51v). This one as a clock input ( i_clk )
My first idea was to connect Pmod DA3 clock to XADC clock creating a unique clock for the entire design. This design was validated. Creating a HDL Wrapper, it has a correct synthesis, implemetation and bitstream. Programing the board i dont get any analog value for output Pmod DA3, it only works output LED[15:0]. Captura.PNG
Modules works correctly independently.
Should i make a differente connection for clocks?
I dont know if there is a clock problem or other type problem.
i attach the project
Can anyone help me?
Thanks!
