mguilbault
Impedance and length matching on the XM105 Debug card
For the XM105 Debug Card.  I would like to know if the lines between the FMC HPC connector and the LA, HA and HB I/O headers are impedance controlled (100 ohms) and length matching.  I think these lines are used to transmit LVDS signals.
Thank you for your help.
Mathieu
mcgett
The FMC-XM105 debug module is not intended for high speed data transfer.  If want to do this then you should look at the FMC-XM101 LVDS QSE module.
