Implementation error when I set PACKAGE_PIN and IOSTANDARD for clock
My development board is VCU108,
I know pin AL22 is single-end clock after I read datasheet.
So I assign it my in .xdc file
set_property PACKAGE_PIN AL20 [get_ports clk_in]
set_property IOSTANDARD LVCMOS18 [get_ports clk_in]
then implementation error occured.
But if I move above code in my .xdc file,
implementation can pass.
My source code just very easy for clock and button test,
module like:
module counter_and_button_test
( input reset_n_in, input clk_in, input [1:0] btn, output and_out, output [3:0] cnt_val_out );
I want to know how to solved it.
Re: Implementation error when I set PACKAGE_PIN and IOSTANDARD for clock
Can I ask why are you using the AL20 pin ?
Have look here, page 41
https://www.xilinx.com/support/documentation/boards_and_kits/vcu108/ug1066-vcu108-eval-bd.pdf
This pin is the dedicated EMC Clock pin, used in configuration, If your not configuring, its not the clock to use..
https://forums.xilinx.com/t5/Processor-System-Design/EMCCLK-pin/td-p/490728
I dont know the board, but at a quick look id suggest you look at using SYSCLK2_300_P
OK, thanks your reply.
I just want to use single-end clock.
It seems that only differential clocks can be used on the VCU108.
So I need to transform differential clocks into single-end clock with some ipcore component.
Is it?
Yep,
Id recommend that you bring the clock in via a MMCM , an IP block,
that has the option in the IP to accept a differential input clock, and output single ended clocks, at different frequencies if you so wish.
Hi:
After readed your reply,
I have a problem.
The output clock of MMCM can be used in reference clock of Transceiver?
Nope is the best answer .
There are two clocks there. One inside the fpga , is from the mmcm, the reference clock into the gtx is special.
Transevers are special cases , they need very good clocks.
If your using the wizard for the gtx, the clocks are an option in the setup .
