Visitor andy.qualls
Instantiating an IBUFGDS on the SGMIICLK inputs of the ML605
I am attempting to implement a design on the ML605 Eval Board.  However, when I attempt to place an IBUFGDS using the SGMIICLK at the H5 and H6 loccations I get a PACK1107 error.
Obviously, looking at the ML605 schematics the signals SGMIICLK_Q0_P and SGMIICLK_Q0_N are routed to H5 and H6.
The master ucf file contained in the board documentation has those signals placed at those locations.
Am I attempting to instantiate the wrong kind of input buffer?  Is there some other setting that I am overlooking?
Professor
Professor
Re: Instantiating an IBUFGDS on the SGMIICLK inputs of the ML605
If these pins are a GTP or GTX reference clock, then you need to use an IBUFDS without the "G".
The IBUFGDS is only for fabric global clock inputs.
-- Gabor
-- Gabor
Visitor andy.qualls
I modified the instantiation and changed it from an IBUFGDS to IBUFDS and I still get the same error.
Professor
Professor
Can you post the complete text of the Pack error?  Note that if the error has multiple
lines, you may not see all of it in the messages view or the error tab.  Then instead
you should look directly at the report file for the full text.
-- Gabor
-- Gabor
You are using the wrong primitive.  The V-6 GTX User Guide, UG366, documents the correct usage in the Reference Clock Input Structure section which is a IBUFDS_GTXE1
