Newbie sagiftw
Is KC705 compatible with TI's ADS4249EVM (ADC) and DAC3482EVM (DAC)?
Hello.
I would like to know if KC705 boards can be connected to those TI boards:
ADC
http://www.ti.com/tool/ADS4249EVM
Connected to KC705 via this adapter:
http://www.ti.com/tool/fmc-adc-adapter
And this board:
DAC
http://www.ti.com/tool/DAC3482EVM
Connected to KC705 via this adapter.
http://www.ti.com/tool/fmc-dac-adapter
I would like to buy 2 pcs. of the KC705 board.
On the first one, I want to connect the ADC board via the ADC adapter + XM105 board for high speed uPP DSP bus + SPI signals + UART.
On the second one I want to connect the DAC board via the DAC adapter + XM105 board for high speed uPP DSP bus + SPI signals + UART.
On TI’s web pages or forums, nothing is mentioned about the compatibility of KC705 card because it is a relatively new card.
The documentation on those cards most probably has been written before the KC705 was presented.
I would like to know which port is compatible with the TI card and which with the XM105 card (I.e. which one to connect to LPC and which one to HPC?)
Are all the signals compatible?
I’m quite new to Xilinx and any help would be highly appreciated.
Thanks in advance.
Re: Is KC705 compatible with TI's ADS4249EVM (ADC) and DAC3482EVM (DAC)?
FMC is just a spec that we follow. If the card is FMC compliant then it should work with our kc705. Looks like we have a few ARs around the KC705 and the XM105. https://www.xilinx.com/support/answers/52888.html
