samokaad
Is "Xilinx Zynq-7000 SoC ZC702 Evaluation Kit" compatible with "Xilinx FMC XM105 debug board" ?
Hi all,
I need to know if I can use the XM105 FMC debug board with ZC702 eval board to access to the FMC pins ?
Xilinx Zynq-7000 SoC ZC702 Evaluation Kit : https://www.xilinx.com/products/boards-and-kits/ek-z7-zc702-g.html#hardware
Xilinx FMC XM105 debug board : https://www.xilinx.com/products/boards-and-kits/hw-fmc-xm105-g.html
Best Regards,
ddn
Hi @samokaad ,
Yes, you can use XM105 on ZC702 Board. Refer below image for your reference :
Hope this helps you.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
ddn
Hi @samokaad ,
Deepak D N
samokaad
Thank you very much for your reponse
