Kylepc
Is there any xilinx development board using QSPI PSRAM?
Recently, I hope to find a xilinx development board using RAM with spi protocol, for example, the development board includes IPUS-PSRAM.
thank you in advance
anatoli
Hello @Kylepc ,
The best place to start for you, in relation to be able to find the correct board for your design, is to reach out to your local Xilinx Sales Representative/Xilinx FAE/Authorized Distributor, as they sale Xilinx boards, so they would know and would be able to recommend you in relation of the required and correct board for your application.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
Hello @Kylepc ,
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
Kylepc
Hi anatoli, thank you for your reply!I will contact an authorized dealer.
