JTAG Detection problem on Herdware
 I am facing problem while detecting JTAG on Hardware. Its showing as below
Re: JTAG Detection problem on Herdware
Hi @balrajks,
Could you give more information?
- Which board are you using (custom board, Xilinx/Avnet/Digilent... board)?
- Were you already able to use the JTAG?
- Are you using a VM? Is the jtag connected to your local machine?
Florent
Florent
Re: JTAG Detection problem on Hardware
Thanks for the reply
    1). Its a custom Xilinx Board.
    2). Yes we were already using the JTAG. For the first time when we bring up the board, We were able to detect JTAG, after that we ran sample project after that once we switch off and switch on the board, we were not able to detect the JTAG.
    3). JTAG is connected to Local Machine.
Balraj
Can anyone help me to solve the issue.
can you try in Vviado programmer tool instead of SDK and let us know the log files to see the message in vivado programmer
Hi ,
 Thanks for the reply.
PFA,
Balraj
Hi ,
        Can you please help me.
 can anyone please help me out. I am stuck here
