Observer tte_yoshida
Jumper setting to set USB device with ZCU111
I am trying to set up the RFSoC as a USB device by connecting J96 to a PC with ZCU111, but the PC does not recognize the RFSoC.
Table 3-13 of UG1271 (v1.3) states that it is the setting of USB 2.0 high-speed on-the-go (OTG) mode, and suspects the influence of the jumper setting.
The ZCU102 clearly describes the settings for using as a device, how should it be set in the ZCU111?
Re: Jumper setting to set USB device with ZCU111
Hi tte_yoshida,
The options in Bold letters are the ones for OTG.
I've never tried it and the connections are different than in ZCU102, particularly that 10 kOhm/1 kOhm resistor.
Andres
Hi tte_yoshida,
Andres
Hi, Andres
Thank you, I understand it.
tte_yoshida
