c_nystrom
KC705 TRD Driver Installation not working
So I am trying to setup the TRD for the KC705 evaluation board. I have the Fedora 16 os setup on my computer, and I have the design loaded into the board. I have been following the directions in the TRD user guide,
https://www.xilinx.com/support/documentation/boards_and_kits/kc705/2014_3/ug882_K7_Base_TRD.pdf
and I reached the point where it asks me to run the k7_trd_lin_quickstart.sh file. When I run it, is hits an error and says:
/bin/mknod: missing operand after `0'
Try `/bin/mknod --help' for more information
make: *** [insert] Error 1
I am not sure what this means.
Thanks in advance.
Tags (2)
c_nystrom
The TRD comes with two .bit files and I put the wrong one on the board.
c_nystrom
