barryvjpl
KC705 power requirements
What is the nominal current draw from the 12V power connector on the KC705?
kdeshwal
Hi @barryvjpl ,
Refer to AR#67507.
It states the following power supplies to KC705:
100 - 240VAC Input,
12VDC 5.0A Output
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
barryvjpl
5.0 A is the maximum the power supply can put out; I doubt that's what the board draws, which is what I need to know, since I'll be using a different supply.
kdeshwal
Hi @barryvjpl ,
This is the characterized and recommended power supply.
Yes, you are right that this doesn't means that the board will always draw 5amp current but using different power supply can possibly varies the results or may be life of board.
Kuldeep
