yu.peng
KCU105 System Controller display wrong name of "KCU1250" or "UNABLE to determine board type"
I bought 2 KCU105 evaluation board, when I plug mezzanine card on them, the VADJ_1V8 power supply remains 0V. So I connect the System Controller through serial port to set the VADJ_1V8.
However I found 1 board display that the board type is KCU1250 and there is not command option to set the VADJ_1V8, see the following screen shot:
And the another board display that "UNABLE to determine board type from EEPROM" and ask me to set the board type and revision, see the screen shot:
yu.peng
Problem solved.
It is because the mezzanine board and the reference design with it has some problem and reset the I2C multiplexer.
yu.peng
Problem solved.
