Visitor suisui0207
KCU105 board Interface test can not found COM port
I am trying to run the test software (called kcu05_bit.exe, downloaded from xilinx's web page). However while starting the software says 'The Standard COM port for the board was not detected. The test will not work. Continue?'. Can you help me solve the problem?
But tera term app can identify the COM port and device manager also can identify COM ports.
Both vivado and the test .exe are 2015.4 version.
Re: KCU105 board Interface test can not found COM port
Hi suisui,
I'm glad to hear it was useful!
If this worked for you, please Accept the Solution to benefit other users.
Andres
Hello @suisui0207,
Can you please share the following details with us:
1. Which Operating System you are using?
2. Can you please check your firmware version. To check the firmware version, connect Tera Term to COM and set the Baud rate to 115200 and type @ver. Please share the results with us
3. Did you installed the USB UART driver? If no, please install Silicon Lab 6.7 version from below link:
https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
3. Please share the screenshot of your Device Manager Port when board is connected.
Naveen
Visitor suisui0207
My Operating System is win7
I have already installed USB UART driver
KCU105 system controller v1.0
Hi suisui,
Can you confirm that you're using driver v6.7?
For that, right click on the item on Device Manager and choose Properties:
Andres
Visitor suisui0207
Yes,I have already installed driver below. I also use tera term set clock frequency, when I testing, I also close tera term windows
Hi suisui,
Please uninstall 6.7.6.2130 and choose "Delete driver" and install v6.7 from here:
and let us know if that helps.
Andres
Visitor suisui0207
Yes it's useful, thank you very much!
Hi suisui,
Andres
Visitor jie3010
I have same problem here, using 10.1.8.2466, it can not found COM port. Can you help me?
Jie
Hi jie,
Can you please roll back to 6.7.0.0 and see if that fixes it?
Andres
