KCU105 reboot problem
Issue with rebooting the KCU105 development card.
After running an application on my KCU105 development card for an hour or so and then rebooting by cycling the power it fails to initialize, and LED DS3 illuminates red together with LED DS18 not lit green. This I believe indicates a problem with the VCCAUX supply. If I leave the card powered down for a few minutes it boots up ok.
I have tried this on three different cards and get the following results...
743109961511-33389   - Always fails to reboot after warm up
743109961511-33424  - Occasionally fails to reboot after warm up
743109961510-32753  - Never fails to reboot after warm up
Does this suggest that there is a problem with a later batch of development cards?
A colleague noticed that one of your answer records AR#65218 mentions that…
“If power issues are encountered on the KCU105, reprogramming these
devices might become necessary, using the Maxim InTune PowerTool
cable.”
Could you please confirm as to whether or not this would cure the reboot problem and if not, what should I do to resolve the issue?
Thank you
Richard Phillips
Re: KCU105 reboot problem
r,
First,  what are you loading into the device?  Did you exceed the power rating of the supply?
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi Austin
I don’t think that we are exceeding the capabilities of the card.
We’ve used the Xilinx IPI Reference design as a reference in our estimates for power usage. We thought that our code was similar enough to the Xilinx IPI Reference design that it should be ok.
I’ve attached the outputs from the power reports for our project. The estimated power usage for the Xilinx IPI project is higher than for ours.
Richard Phillips
r,
The power report confidence is low, so it might be more watts than is estimated.  I would check the die temperature through the Vivado hardware monitor pull down screens.  Watch the die temperature after loading, and see what maximum value it reaches.
I am assuming this does not happen when no pattern is loaded (that the board itself is good until the bitstream is loaded).
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi Austin,
I've erased the configuration memory and I still get the reboot problem.
I also checked the die temperature as you suggest and after running the application code for about half an hour the temperature stabilizes at 33.6° C.
Richard Phillips
r,
OK, that means there is something wrong on the board somewhere.  Go back to the distributor and start the discussion for getting them replaced/repaired.
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi there,
I am having same/similar issues here. I programmed my card couple of times without any problem, but now I get DS18 off (VCCAUX_PGOOD low) and DS3 red. I also realized that it only happens if I try to download a MicroBlaze processor-based system to my board. Downloading another simple firmware seems to work just fine.
Did you solve your problem ? If yes, what was the solution ?
Cheers, Csaba
Csaba
@csaba.soos This thread is closed and old. It is good practice to start a new thread to get the quick attentation.
Did you see this problem when loading Xilinx design files provided with the board?
-Pratham
The problem was fixed by obtaining a Maxim PMSbus dongle (free of charge from Maxim) and using the attached XML file to re-program the voltage regulators - don't use the XML file from the web site as it makes matters worse!
Hi Pratham,
thank you for replying. I tried the KCU105_IPI design (version 2016.1) and it does fail too. While trying to debug, 1 out many attempts I got it working again, but it keeps failing other times. Most of the time VCCAUX shuts down, but a couple of times I had VCC1V2 failing.
Regards, Csaba
Csaba
Thank you for your reply. I just ordered the free dongle. We shall see what happens when I program the controller.
Regards, Csaba
Csaba
@rep1 Okay, Let us know the result after reprogramming power controllers.
-Pratham
