Kintex Ultrascale FPGA KCU 1500
I am thinking to use the KCU 1500 to accelerate some software algorithms.
I wanted to learn the architecture of this device like the interconnect interfacing, memory interface, system addresses, etc. so that I can implement the IPs on this device.
May I know a good source of documentation on that?
Thank you.
Mentor jmcclusk
Mentor
Re: Kintex Ultrascale FPGA KCU 1500
How about UG1234?   SDAccel Platform Reference Design User Guide for the Kintex UltraScale KCU1500 Acceleration Development Board.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug1234-ref-design-dev-board-accel-kcu1500.pdf
@jmcclusk - Thank you!
@jmcclusk -
I have a custom software programmed in visual studio (around 30k lines of code) which processes the ADC data from the digitizer.
I am looking to accelerate the software so that I can process the data in near real time!
I think KCU1500 board should be a good choice for this application.
Do you have any recommendation for any other board that I can use? Also I need a board which has PCIe gen3.0 x4/x16!
Thank you.
HAL(hardware abstraction layer) driver is interfaced with the Linux kernel mode driver (xcldma).
Does that mean that the accelerator is compatible with only Linux operating system?
I am looking for an accelerator that is compatible with Linux as well as Windows!
