Observer wangxiao@skhms
Looking for VCU128-G board file
Currently Xilinx supports two VCU128 EVBs, VCU128-G (production) and VCU128-ES1-G, but the Vivado tool only supports the board file for VCU128-ES1-G (we are able to install the vcu128-es1 board file using xsetup or github), which defines the FPGA as xcvu37p-es1.
The problem is that we spent more $ for VCU128-G, but its license only support for xcvu37p and not for xcvu37p-es1, so there is not board file we can use for VCU128-G.
To solve the issue, Xilinx should support either the board file for VCU128-G or to add xcvu37p-es1 into VCU128-G license.
Xiao
Re: Looking for VCU128-G board file
Hi Andresb,
I downloaded and installed this new VCU128 board file, and it works fine and the license issues is resolved.
Thanks for the help!
Xiao
Hi wangxiao,
The Board Files for the Production board can be found on RDF0491 (IPI Tutorial).
Download the zip file:
https://www.xilinx.com/member/forms/download/design-license.html?cid=b0612e8b-99ea-4023-a9e0-a5b2b7999a97&filename=rdf0491-vcu128-ipi-c-2019-1.zip
And you'll find them in this folder:
\vcu128_ipi\vcu128_board_flow_files.zip\vcu128\1.2
Hope this helps,
Andres
Hi Andresb,
Xiao
