matan_n
Looking for Virtex + SoC EVK
Hi all,
I currently use a ZC706 for prototyping, but I'm running out of I/Os and logic / DSP / memory.
I'm looking for a bigger FPGA EVK. I need at least 1,000,000 logic cells and 5,000 DSP slices (and around 50 Mb of memory).
for I/Os, i need 8 transceivers and 30 I/Os or 200 I/Os.
I also need to keep that dual core ARM processor... a uBlaze seems too weak for me, and will also require too much software and bring-up effort right now.
My leading solution for now is connecting the ZC706 to a VCU118 using transceivers and splitting the logic between them.
I'd much rather have a single - board solution, or a single board with mezzanine.
any suggestions?
thanks!
balkris
I would recommend you to contact your local Distributor with givven requirements
Suggestion may not make sense until unless you know cost and board availability
https://www.xilinx.com/about/contact/sales-reps.html
Thanks and Regards
Balkrishan
hbucher
@matan_n
What about a ZCU102? It is in production release now
matan_n
Thanks @hbucher,
I've considered it, but it's a little tight in terms of FPGA size, and I don't want to migrate to it just to be out of resources in a couple of months...
