Looking for letter of volatility for a HW-USB-II-G
Request info for how to get a letter of volatility for a HW-USB-II-G.
I'm also looking for this.  Any luck?
Hello @jondenning , @drussack ,
Since NDA must be in place and verified with Xilinx Legal, this is an internal information and can't be openly shared on forums.
For this, you'd need to raise SR here in order to get access to it.
Or, if you don't have a direct access to open SRs with Technical Support, in this case please contact Authorized Distributor from where you purchased this cable, and they can then raise an SR on your behalf.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Thanks for the update.  How specifically do I write the SR?  It does not seem like there's a valid category when I go to submit an SR.  I tried Technical->Xilinx Product->All Other Devices, and it points me back to the forums.
Hello @jondenning ,
Thanks for letting us know.
In this case, i've manually created a new SR (SR#10497626).
An Engineer will contact you shortly on this matter.
Have a nice day.
Kind Regards,
Anatoli Curran,
Hello @drussack ,
In case you are also seeing this issue, the SR # 10497627 was created on your behalf.
A Product Application Engineer will contact you shortly on this request.
Hope this helps.
Kind Regards,
Anatoli Curran,
Hey everyone, I'm looking for this information as well too
Hello @jayparker14 ,
As indicated above, since NDA must be in place and verified with Xilinx Legal, this is an internal information and can't be openly shared on forums.
Hope this helps.
Kind Regards,
Anatoli Curran,
