Observer chaoyangzhu
MAXPOWERTOOL & TAX ID
我买了一套zcu102开发板,箱子里有一张说明书显示我可以从www.maximintegrated.com/powerxilinx上免费获取dongle和powertool sofaware。我在该网站上获取样机时,在shipping环节需要填写TAX/Broker ID。请问这个税号是什么?我从何获得?
Re: MAXPOWERTOOL & TAX ID
Hello @chaoyangzhu ,
You should just be able to navigate to https://www.maximintegrated.com/en/storefront/search_result.html?type=sample&sampleSearchField=MAXPOWERTOOL002&cq_ck=1569332613649 and click on SAMPLE as shown below:
Once done, if you just proceed to check out, it should not ask you for any TAX/Broker ID.
Please give this a try and see if you can order one using the SAMPLE option as indicated above.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hope this helps.
Kind Regards,
Anatoli Curran,
Thanks. I have got the sample order comfirmation. I tried as you suggested while the TAX ID was still required. Then I used the TAX ID of my college, and it succeeded.
