MIG DDR3 init_calib_complete not go high on KC705 board
 I used the MIG DDR3 softcore to communcation with KC705 on board ddr3,the simulation is ok ,but the init_calib_complete never go to high when I on board.
 I have checked the mmcm_locked is high,and the Initialization signals are ok as well(attached as below).
 Now i post some information about the design configure.
  a) tool
     software:Vivado 2016.1
     hardware KC705
  b)MIG configure
    1) Create Design, 1 controller, with AXI interface
    2) no pin compatible FPGAs
    3) Select DDR3 SDRAM
    4) Clock period: 1250ps (800 Mhz)
      PHY to Controller Clock Ratio: 4:1
      Components: SODIMMs
      Part: MT8 JTF 128 64Hz - 1G6
      Ordering: Normal
   5) AXI datawidth: 64
     Arbitration Scheme: WRITE_PRIORITY
     ID Width: 4
   6) Input Clock period: 5000ps (200Mhz)
     Read Burst Type: Sequential
     Output Driver Impedance Control: RZQ/7
     Controller Chip Select Pin: Disable
     RTT - On Die Termination: RZQ/6
   7) System Clock: No buffer
     Reference Clock: No buffer
     Reset Polarity: Active Low
     added debug signals for 1024
     XADC Instantiation= ENABLED
   8) DCI Cascade = checked
   9)Pinout know is fixed
 c)hardware configure
  1)clock:KC705 system differential clock input(200MHz) ,use IBUFGDS to give it to sys_clk_i and clk_ref_i
  2)reset: use the Dip switch as the sys_rst_n(low active),and checked the ddr3_reset_n state with the led is ok.
  below is the ILA capture data for ddr3_initialization signals:
Re: MIG DDR3 init_calib_complete not go high on KC705 board
before doing all of this debug please use the ready to download bitfile from the KC705 page and verify that the board is functioning correctly
https://www.xilinx.com/products/boards-and-kits/kcu105.html
