Visitor yuriom
MIG wrongly exposes dm_n[0:8]
I have been trying to access a custom DDR4 module on my VCU1525 with IP Integrator in Vivado 2018.3. For some unknown reason, the Memory Interface Generator (MIG) keeps exposing dm_n[0:8] pins even if I choose "NO DM NO DBI" for the "Data Mask and DBI" option. What should I do with these pins?
Visitor yuriom
Re: MIG wrongly exposes dm_n[0:8]
Actually, I was getting the dm_n[0:7] pins precisely because I chose a non-ECC DDR4 memory module. If you select an ECC-enabled module, you do not get dm_n. This rule was clearly stated in the manual for the MIG IP.
It is probably because you have selected RDIMM.  Those pins are on the connector pinout so you must drive them to the correct value for the DIMM to function.  The selection just applies a static value and the correct mode register settings.
If you don't have a registered DIMM don't select that configuration.  If you have a custom board with build in memory you need to select component instead.
Visitor yuriom
