ML410 and VGA TFT controller
Hi;
I am trying to use the VGA display (plb_tft_cntlr_ref_v1_00_d) with ML410 board, but it shows only vertical lines and no image is displayed. Following are my .mhs, .mss, and ucf instantiations of the tft controller IP (http://www.xilinx.com/univ/xupv2p_demo_ref_designs.htm Slide Show). The IP works fine with the XUPV2P board. Please help me resolve this.
--Rajeev
Re: ML410 and VGA TFT controller
I am experienced in plb_tft_cntlr_ref 1.00.c, this is not the same version as yours.
Although the following SYS_plbClk and a SYS_tftClk parameter were set up in plb_tft_cntlr_ref 1.00.c,
if it confirms whether to be necessity or not by your design.
 PORT SYS_dcrClk = CLK_100MHz
 PORT SYS_plbClk = CLK_100MHz
 PORT SYS_tftClk = CLK_25MHz
Best Regards,
Yoshio Kashiwagi - Nissin Systems
Hi;
I tried everything but still the VGA is not working, any help or usf/mhs files are highly appreciated.
Aamir
I'm also working with this core in the XUP, and I'm experimenting some problems, when I rst the system, It start writting in different vertical position, It is reported since 2007 in this post http://forums.xilinx.com/xlnx/board/message?board.id=Virtex&message.id=339&query.id=27816#M339.
By the other side, if you try to show an Image of the size 640x480, it'll show vertical lines. You should cut your image, or you'll see vertical lines, I'm doing this way:
        for(i=5; i< 475; ++i){
            for(j=5; j< 635; ++j){
                aux = (* (image1 + i*480+j));
                pix2 = aux>>8;
                XTft_mSetPixel(frame1, i, j, pix2);
Anyone knows, what XTft_Initialize(tft_config,0) should do?? it halt my system.
This core isn't working at all, it really need a revision or a more extended documentation.
Hi;
Try the following, make sure you provide the right base address. The code related the VGA iis in files xtft*
#define XPAR_XTFT_NUM_INSTANCES 1
#define XPAR_TFT_0_DEVICE_ID 0
#define XPAR_TFT_0_DISPLAY_BASEADDR 0x00000000
XTft_Initialize(&xtft, XPAR_TFT_0_DEVICE_ID);
tft_addr = xtft.BaseAddress;
xil_printf(
"BaseAddress = 0x%08x\n\r", tft_addr);
XIo_Out32(CTLR_ADDR + 0x40, tft_addr);
xil_printf(
"Wrote 0x%08x to 0x%08x\n\r", tft_addr, CTLR_ADDR + 0x40);
XIo_Out32(CTLR_ADDR + 0x44, 0x1); // turn on display
xil_printf("Wrote 0x%08x to 0x%08x\n\r", 1, CTLR_ADDR + 0x44);
XTft_ClearScreen(&xtft);
XTft_SetPos(&xtft, 580, 2);
Aamir
If you still looking to VGA controller, I wrote somthing you can call LL_VGA_Controller and I integrate it into EDK pcore.
It connected PLB (V4.6) for Reg. setting and has Local Link connection to the MPMC to get the RGB data from External Memory.
It is also support VESA standards like 640x480, 800x600, 1024x768, 1152x864, Custom and more...
RGB: 111,444,555,565,888 ...
I tryed it on PPC, Microblaze, ML405, Spartan3DSP Kit, Spartan3E Starter Kit and it workes OK.
If you need it send me an email.
--Guy
Hi;
Thanks for your email, I would appreciate if you can provide me your VGA controller with all the details. My email is aamirf@avieon.com
Aamir
Hi guyosi,
          That core seems so taste, I'm developing under EDK 10.1 and Digilent has stopped the de support, could you send it to me too please?.
  My mail is greenlean@gmail.com.
Thanks..
Please can you send it to me, too?
my E-mail: michael.hohenforst@web.de
can you send it to me to,
de_gerrit@hotmail.com
Could you send me one please? I have been tied to the VGA port on ML507 for two weeks. Many thanks.
eexly6@nottingham.ac.uk
Im looking for good VGA controller for ML507.
If it is possible, you can send Your example to me.
miv5@o2.pl
Hi all,
Please guyosi could you send me your VGA controller? It would be great because I have been looking for a VGA controller which can be used with EDK 10.1 and I found nothing.
Mi mail is pablocolodron@hotmail.com
Thank you very much,
If you can send your controler to me, it will be very appreciated !    gabriel.lheureux@polymtl.ca
Gab
Can you send the VGA controller to me? It will help a lot for my project.
Thank you very much...
ersin@rice.edu
I am an academic trying to set a lab on video decoding.
I would be very grateful if you could send it to me also.
sebastian.mailbox@yahoo.fr
Best regards,
Sebastian
Hi there,
can you send me your VGA controller too?
my email is jonas.b.coppens@gmail.com
Thanks in advance!
thanks, my mail: lilubacd@163.com
I need the VGA controller,please send to me. yanwei0623@126.com
thanks!
Would you please send it  to me !
My email: zyt9999@163.com
Regards!
Attach is link to download the IP + Basic Docs + ML405 example on EDK 10.1.
The file will be at the FTP for 7 days.
http://xfer.avnet.com/uploads/VGA_CNTR_EDK_10_ML405.zip
Free Code, No Warranty.
Good Luck
Guy Osi
Hi Guy Osi,
I really appriciate your work. I need vga ip for spartan3e 1600e kit for academic purposes, I will compare hw accelerated mpeg2 with sw accelerated version.
My board output is VGA and EDK 9.2i does not have a tft controller lib like EDK10 or above.
Thanks for yor help,
Murat
Just migrate the design to 10.1.3 then to 11.4,
The benefit you will have with 11.4 is grater then the benefit to avoid it.
--GO
Hi,guyosi
I have work with tft controler for a whole week , but I get nothing on my LCD
my board is XUPV2P , and EDK 10.1.03
can you send me your core of  VGA controller,I need your help
I would appreciate your work
my email is : hyy7792354@163.com
 thank you
Anonymous
Not applicable
Hi Guy Osi,
Can you please send me your source code? I have tried upgrading the xilinx TFT controller to support a 1024x768 resolution but so far no luck. I need a working VGA interface for my research project. Thanks for the help. Much appreciated. my email is fyacel2008@hotmail.com
Faycel
Hello
I have to show an image using xps_tft  via DVI port but it shows a very distorsioned image . The exemple with colorbars runs perfectly. The image is read from the flash card and i try to show it with
for(row=0;row<480;row++)
for(col=0;col<640;col++)
XTft_SetPixel (Tft,row,col,imagebuffer[k]) ;
k++;
Instructor
Instructor
1.  Start a new thread if you want to introduce a new discussion topic.
2.  The problem description "distorted image" is too vague.  If you want useful answers, please provide useful amount of detail information.  Only wives (well, one in particular) and daughters expect mind-reading to work well, not design engineers -- in my experience.
-- Bob Elkind
SIGNATURE:
Summary:
colorbars example
hello
I try to run the  colorbars exemple which is in "
 , but  nothing is appear in my screen.
I use a virtex 5 board (xupv5).  and I have connected my FPGA  in the lcd screen via a vga port.
in the hypeteminal  I find that :
"Display color
  Writing Color Bar Pattern
  TFT test completed!
  You should see vertical color and grayscale bars
  across your VGA Output Monitor"
  can you please help me ?
Regard
Hi !
Can you give me one ?    my email is RedBayBoy@gmail.com
Xilinx already done a standard controller, you will find it in EDK:
http://www.xilinx.com/products/intellectual-property/xps_tft.htm
http://www.xilinx.com/support/documentation/ip_documentation/xps_tft.pdf
Good Luck ;-)
