Visitor qianse
ML501 PROM not working
The PROM was operating normally untill this afternoon, for some reason I can no longer load the .mcs file from platform rom to the FPGA. I can still download the .mcs file to the platform rom and read back the .mcs file no problem. I can also download the .bit file directly to FPGA without problem either.
I don’t think I have changed any setting. Can you please advice that if I can some how check if it a board problem? Or is it some setting I changed by accident (most likely not). Please let me know the steps of checking. Btw, the DIP switch are all set to “low” for the platform rom setting.
I have observed that the INIT and DONE LED never go high before or after I press PROG button. Seems the downloading of bit file from PROM to FPGA never started.
Thanks for your kind help.
Jason
Re: ML501 PROM not working
HI,
Can you check if the Switch(SW15) - 8 is off. If this switch is on it will select system Ace configuration.
-Krishna
Visitor qianse
Hi Krishna,
Thanks for the reminder, but I have already set the SW15 to off. I had to ensure it was configured for PROM in the first place (when it was working before).
Jason
