Mentor
Mentor
ML505: MIG-generated pin assignments
Hello Everyone,
when I generate a DDR2 controller core, the pin assignments created in the UCF file do not correspond to the master UCF pin constraints, found here: http://www.xilinx.com/products/boards/ml505/docs/ml50x_U1_fpga.ucf. The pin assignments from the reference ML505 MIG Design also do not make sense (for example, NET "ddr2_a[9]" LOC = "N32" ; however, according to the ML505 User Guide, N32 connects to HDR2_10, while the "real" DDR2_A9 pin is R28).
What did I do wrong? Can I automatically correct the generated pin assignments, or do I have to enter them manually (i.e., copy them from the master UCF file and adjust net names)?
Thanks for your help,
Adrian
Please google your question before asking it.
If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
