04-28-2012 03:16 AM
I'm following "ML505/506/507 MIG Design Creation" to test a DDR2 design, but I found that even if I follow that document exactly to configure my ML505, when I switch on the board, I cannot read any signal from the differential outputs (J12 and J13) using a scope, and (hence?) the "phy_init_done" never goes high. Both pins read 1.19V. Am I missing anything?
My settings on the board are:
04-29-2012 02:59 AM
Turns out that the measurement problem is related to my scope which cannot measure differential signal properly.
My ML505 works fine with the sample file (ml505_mig_design.zip).
Thread closed.
04-29-2012 02:59 AM
Thread closed.
