Visitor gndrix
ML507 board revisions
Hello, we are working with embedded linux on the ML507 board with a power PC into the virtex 5. The linux distributions are generated using POKY platform builder. We have two ML507, one with a "rev 1" tag on the bag it comes packed in, the other one says "rev 4". in "rev 1" everything runs just fine, the bitstream is written from the compact flash and the linux system is started through u-boot without any trouble. Unfortunately on rev 4 it does not work. Which are the differences (if any) between rev 1 and rev 4. We think there must be something different and haven't found any info about it.
Thanks in advance
Scholar austin
Re: ML507 board revisions
Did you read through this thread:
http://forums.xilinx.com/t5/Embedded-Linux/ML507-and-marvell-88E1111-revisions/td-p/119546/page/2
I suspect that similar to that post, the problem has nothing to do with linux....
Austin Lesea
Principal Engineer
Xilinx San Jose
Teacher eteam00
Use this thread link instead, in case you have trouble:
-- Bob Elkind
SIGNATURE:
Summary:
Visitor gndrix
Thanks for your answers, i've already read that thread, I do think it something similar. What I think is that the problem has nothing to do with linux as it runs correctly on the old board. So we think there's something different with the hardware, or some parameter related to it in the new board rev 4. Where would you suggest to start digging?. In the new board the boot process stops because some environment variables are missing for u-boot to use them. So I add them by hand and doing this the bitstream can be written and u-boot knows what to boot (:S). Unfortunately, after, uncompressing the kernel image and loading the device three, it stops working. Any suggestion?. Any hint would be greatly appreciated!
Thanks in advance.
 > So we think there's something different with the hardware, or some parameter related to it in the new board rev 4.
There was only a single PCB version of the ML507 released and that is Rev A.  If your two boards have labels that say rev 1 and 4 this is something that someone on your team did.
Visitor gndrix
Actually, we didn't, but maybe those labels doesn't mean anything. However, there must be some differences between the boards, it's just that we haven't found anything yet.
