ML605 Embedded Kit Video Demo
I am having trouble running the Video Demonstration provided in the Virtex 6 FPGA ML605 Embedded kit manual.
1. I have changed the IP address to 192.168.1.100 and set the browser URL to 192.168.1.10 with the board connected to LAN; however, nothing ever shows up and it times out. The jumper settings are correct, as far as I can tell. Am I doing this wrong? I changed the Local Area Connection IPv4 to the specified one, then checked command prompt and it was set correctly.
2. The Xilinx Logo does not appear on the VGA monitor which I have connected through the VGA to DVI converter.
Random vertical green and red lines appear on the screen, but no message.
I believe the Compact Flash card is working properly because there are no red lights blinking on the board.
Thanks in advance for the help!
