ML605 FMC Power
Dear colleagues,
I need to design an FMC (HPC) mezzanine with 4 ADC channels @ 250 Msps, which would consume quite a lot of power. Depending on the ADC choice, I can possibly have about 2.9 A in the 3.3V supply. This mezzanine will be used on the top of a ML605 kit.
My question is: can I use 2.9 A from the 3.3V supply in continuously? We are concern about damaging the HPC onnector, or long term problems related to oxidation, etc. The ML605 hardware user guide says:
Voltage Supply         Allowable Voltage Range    No Pins        Max Amps        Tolerance           Max Capacitive Load
      3P3V                                     3.3V                               4                      3                    +/- 5%                         1000 uF
My concern is being very close to the allowed power in a steady state regime.
Thanks in advance.
Anonymous
Not applicable
The ML605 Hardware User Guide has Table 1-29 Power Supply ratings for FMC-HPC Connector. According to that it can support upto 3A.
Anonymous
Not applicable
