ML605 - LCD User Manual
I am working on Ml605 (Virtex-6 LX240T) evaluation kit and I want to program(in Verilog) the LCD on it. I am unable to find the details of the LCD functioning.
Can anyone help me with the manual for the LCD of this board.
Raju
Tags (2)
Re: ML605 - LCD User Manual
The ML605 Hardware User Guide includes information on the LCD manufacturer and partnumber.  I'm sure that if take this information and plug it into Google a user manual can be found.
Not sure what you are looking for.
The manual for Display Tech's LCD (162D) is here: http://www.displaytech.com.hk/upload/product/attachment/984-162d%20series-v30.pdf
 but this may not help you program it.
The user guide for the board is here: http://www.xilinx.com/support/documentation/boards_and_kits/ug534.pdf
You can search the Xilinx Forums for Verilog, LCD, and code - there are some nice folks who have shared their working code for other boards.
I'm new to this so please pardon me. I'm using EDK 12.1.
I followed the ML605 Built-In Self Test Flash Application (rdf0017.zip) reference design's hello_lcd code but am not experiencing success. This is what I did:
After creating a new project and using Base System Builde (BSB), I followed rdf0017: added a xps_gpio, connected it to the LCD pins (again referencing rdf0017's ucf file) using the GPIO_IO port. Then I used hello_lcd's src files to build a simple application. However, maybe because of v12.1, some of the xgpio functions in the src file (lcd.c) have been removed. So I had to modify the XGpio_mSetDataReg and XGpio_mSetDataDirection to XGpio_WriteReg (of course using the correct register offsets).
To summarize, what I did are:
1) use a system clock of 100MHz, same as rdf0017
2) added a xps_gpio to drive the LCD pins following exactly rdf0017's way
3) modified the lcd.c code to use XGpio_WriteReg because EDK 12.1's gpio version has removed XGpio_mSetDataReg and XGpio_mSetDataDirection.
However, doing these steps, I am unable to get the LCD to work (nothing is displayed). Am I missing something? Thanks.
I have same problem?
Can anyone help or is there any update to this post?
thank in advance
