ML605 configuring the FPGA using System ACE compact flash.
I am seemingly unable to configure the V6 Fpga on the ML605 board using the System Ace.
I have a bit file that contains a logic design with an EDK system in it and a bootoader which launches my application which is programmed in FLASH.
This bit file works when I use iMPACT12.4 to program the FPGA.
To use system ACE, I (because I can find no documentation elsewhere), open iMPACT, then on the "Welcome to iMPACT" screen, click "Prepare a System ACE File", then click "OK", leave "Novice" selected, click "Next", select "Generic" as my CF is the 2GB Transcend CF that came with the ML605, leave reserve space at 0, click next, Set the name to sysace_first, leave the location as it is, click next, check Configruation Address 0, leaving the name as rev0, click Next, click finish, click Ok, then find and select my bit file, click OK. Click NO when asked if I would like to add another device file to config address 0
I then right click "Generate File" and click OK. impact then tells me Generate Succeeded
Looking into the directory, I see a file xilinx.sys and a folder rev0 with rev0.ace inside it.
What happens now? Going back to the Boundary Scan window where is shows the JTAG chain, it shows the sysAce devive and the FPGA, but it won't allow me to assign anything to the SysAce device other than a mpm or a bsd file.
I power cycle my ML605 Board, but it doesn't boot to my design.
I've googled and searched the answer records and the forums, and found where it says do this or do that, But I'm relucant and tired of trying to follow random instructions when i'm not certain the process I explained above is correct or in error.
Am I doing something wrong?
Re: ML605 configuring the FPGA using System ACE compact flash.
http://www.xilinx.com/support/documentation/white_papers/wp151.pdf
http://www.xilinx.com/support/documentation/data_sheets/ds080.pdf
http://www.xilinx.com/support/documentation/system_ace_solutions.htm
You need to copy these to the CompactFlash card (replacing the existing ones on the CF card) using a USB-to-CF reader.  It can't be done in impact or with the USB-JTAG cable.
I looked in all of the these, they provide lots of info about SysACE, but couldn't find where any of them told me what I needed to do on this ML605 Board.
I appreciate your help.I did as you said above and it initially didn't work.
iMPACt created the following in my working directory:
\sysace_first\xilinx.sys
\sysace_first\rev0\rev0.ace
examining xilinx.sys it contains the following:
dir = sysace_first;
cfgaddr0 = rev0;
Looking at the original contents of the CF card they are, among some others"
xilinx.sys
XILINX\cfg0\ml605_bist.ace
XILINX\cfg1\ibert_bank116.ace
XILINX\cfg7
dir = XILINX
cfgaddr0 = cfg0;
cfgaddr1 = cfg1;
cfgaddr7 = cfg7;
looking at this xilinx.sys file and the directory structure, it would seem that xilinx.sys and the directory it points to both need to be in the root of the CF card, based on this, I cut xilinx.sys from the sysace_first directory and pasted it into the root directory, where sysace_first resided. so now in the root of my cf card I have:
xilinx.sys
And this works!
Visitor hfaraz
adding to above post,
the xilinx.sys should reside only in root of the CF and nowhere else (impact is creating one inside the chosen folder also, next to revx folders)
