ML605, obtaining the energy consumption of whole board
I used system monitor to calculate the power consumption of board in ML605, but it just gives the Vccint and Vshunt which are enough just for calculating the power of FPGA chip not whole board.
I saw in system monitor demo which is provided by xilinx that it also shows the voltage and current of board and I need them.
I appreciate if anyone can help me
Morteza
Re: ML605, obtaining the energy consumption of whole board
System Monitor provided to estimate power consumption of FPGA only. If you wish to know power consumption for whole board then use one of the below methods
1) Measure the current practically by meter and estimate approximate power consumption (V X I) from that.
2) Use TI Power Solutions for measuring power on development boards. Refer ML605 user guide power managment section for more details
FYI:
The following PPT http://www.xilinx.com/support/documentation/boards_and_kits/xtp048.pdf can guide to use System Monitor in ML605.
