ML605 system monitor problem on windows 7
I have a ML605 board, windows 7 OS  and xilinx ISE 13.2.
I want to run system monitor and see the power consumption of board so I downloaded the
document "XTP048_12.1_c.pdf" and "rdf0012_12.1.zip"  from xilinx site and followed the instructions in PDF file.
all things are OK till I reach slide 12.
when I run xmd command, it says that there is no internal or external command like xmd and I stuck.
I would appreciate if anyone can help me.
Thanks in advance
Re: ML605 system monitor problem on windows 7
do you have EDK installed? you need EDK system software to use this command.
check the following link for the ISE design suite : embedded edition details
http://www.xilinx.com/products/design-tools/ise-design-suite/index.htm
--Krishna
--Krishna
Hi Krishna
thanks for your response. Actually I have installed EDK, but the problem was that they weren't add to the
Evnironmental variables in windows. I just added the EDK\bin\nt to it and the problem was solved
regards
