ML605 with higher speed grade Virtrex-6
Hi all.
Are there any news about ML605 boards with higher speed-grade Virtex-6? In other words, has  Xilinx intention to produce ML605 boards with higher speed-grade Virtex-6?
Tino
Re: ML605 with higher speed grade Virtrex-6
No.  There is only one speed grade and device size option for the ML605.
