jimd6776
MPSoC ED version
What is the difference in EK-U1-ZCU104-G-ED and EK-U1-ZCU102-G-ED boards between the non ED boards. I've read something about encryption disabled. How will this affect my projects? Does it have the same support in tools, Vitis AI, etc. as the regular non ED boards?
Thanks in advance.
ddn
@jimd6776 ,
Vitis/Vivado tool will give same feature for ED Boards as it provides to Non ED Boards. Only feature which is not available is, if you want to encrypt the BIT File, that is not supported for this board.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
ddn
@jimd6776 ,
Deepak D N
