Mali graphics performance on Ubuntu
I've booted up one of the Ubuntu example designs on my ZCU102, and am experimenting with the graphics performance.  I found that running glmark2 (the software version) gives a glmark score of 5.  glmark2-es2 (the hardware-accelerated version) shows that the Mali driver is running, but also gives a score of 5.  This is, to put it nicely, a little less than I had hoped for.  Is this lack of performance expected, or is something wrong with my setup or the reference design?
Thanks!
Newbie zhangyifei
Re: Mali graphics performance on Ubuntu
I also have the same problem. Mali GPU's driver is ok, but it seems to have no effect.
Do you solve this problem?
I think the problem has to do with X11/XFCE.  If I run it with the --off-screen option, I get much higher performance (>100fps).  If I run the software version with --off-screen, it still gets about the same performance (~5fps).
Basically, even if the window is accelerated, the window manager/X11/something still has to copy the pixels to the screen, and this happens very slowly.  As far as I can tell, the only solution is to run applications in fullscreen mode without any desktop environment (as is done by the "tricube" demo on the UltraZed), or to use a composited desktop (e.g., compiz or kwin).
