Mounting options for ZCU111
Is there a place where it is possible to find the hole patterns for the ZCU111 and XM500 boards? I'd like to make a plate to physically mount the ZCU111+XM500 boards to, but can't find the hole pattern for where the standoffs are located anywhere. Does this diagram exist and - if so - where can I find it?
Re: Mounting options for ZCU111
The normal place to look for this would be the gerber files for the board,
https://www.xilinx.com/products/boards-and-kits/zcu111.html#documentation
Its a pity the mechanical data is not produced explicitly
