Muicrozed board is having Engineering Sample (ES) or Production silicon
I would like to know which Silicon is there on microzed baord (perferarbly without using a JTAG cable) ?
I saw on the chip the fourth line is "1C     "
but nothing follows it.
Engineering silicon is usually marked as "ES". Check if this marking is there on the device. Else it should not be a engineering silicon.
