Need a help in KCU105, MicroBlaze example
Hi all,
Could you help me to find a Microblaze  example project  for KCU105 , Vivado 2015.4 as simliar for ug940-vivado-tutorial-embedded-design.pdf .
Re: Need a help in KCU105, MicroBlaze example
@ukonar There is already example present in vivado 2015.4. Click on example project and select the board you wish to
-Pratham
 Well I'm expecting to use Vivado Logic Analyzer as in ug940-vivado-tutorial-embedded-design.pdf
@ukonar Well, then you will have to follow same instruction given in the UG to create for KCU105
-Pratham
Thank you Sir, but when i tried to replace kc705 (as mentioned in UG) with KCU105 , i'm getting
1>TNS , i've attached screens shots of it . Default clk used is 300MHZ,
2>for debug CLK in UG page 101 i selected ../ddr4_0/inst/u_ddr4_infrastructure_CLK
3>and as mentioned in UG pg 113 of UG when i select Debug , i'm getting error launching program.(screenshots attached).
Please help me to resolve this issue
@pratham could you help me to resolve this issue with exact solution.
Hi, did you find a solution for timing issues? I tried the same thing with similar results...
