darshankumar26
New to Zynq xc7z020 clg484
i am new to this board can any one help in  global clock pin No, any I/O pin as switch
muzaffer
Your question is really vague. For clock pins you can use any pin which has the suffix MRCC in it (if it's single ended pick the _P side).
htsvn
hi,
you have to refer the package and pinout guide for this device available at this link
http://www.xilinx.com/support/packagefiles/z7packages/xc7z020clg484pkg.txt
and refer to mrcc pins that can be used as clocks.
--hs
gnarahar
@darshankumar26 Did above responses help you? If not, as muzaffer mentioned, your question is vague. You may want to post more details on what exactly you looking for and what is it you are trying to implement.
That will help forum members answer to the point and help you.
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
