azfarhussain
Nexys 2 Board LED errors
I get the following errors when I try to light all LEDS of my Digilent Nexys 2 Board.  I follow the pin out naming specs as specified on the board.
ERROR:Pack:1107 - Unable to combine the following symbols into a single IOB
   component:
    BUF symbol "data_out_4_OBUF" (Output Signal = data_out<4>)
    PAD symbol "data_out<4>" (Pad Signal = data_out<4>)
   Each of the following constraints specifies an illegal physical site for a
   component of type IOB:
    Symbol "data_out<4>" (LOC=E17)
   Please correct the constraints accordingly.
   component:
    BUF symbol "data_out_5_OBUF" (Output Signal = data_out<5>)
    PAD symbol "data_out<5>" (Pad Signal = data_out<5>)
    Symbol "data_out<5>" (LOC=P15)
   component:
    BUF symbol "data_out_6_OBUF" (Output Signal = data_out<6>)
    PAD symbol "data_out<6>" (Pad Signal = data_out<6>)
    Symbol "data_out<6>" (LOC=F4)
   component:
    BUF symbol "data_out_7_OBUF" (Output Signal = data_out<7>)
    PAD symbol "data_out<7>" (Pad Signal = data_out<7>)
    Symbol "data_out<7>" (LOC=R4)
Message Edited by azfarhussain on 12-08-2009 04:11 AM
gszakacs
Professor
Professor
Take a look at the reference manual.  There are pinout differences on the 1200 Kgate version.
On page 5 it shows the LED's with pinouts for the 500 Kgate part with 1200 Kgate pinout in parentheses.
LD4: E17 (E16)
LD5: P15 (P16)
LD6: F4 (E4)
LD7: R4 (P4)
These are the same 4 pins you're getting error messages on.  Are you using the -1200 part?
-- Gabor
gszakacs
Professor
Professor
LD4: E17 (E16)
LD5: P15 (P16)
LD6: F4 (E4)
LD7: R4 (P4)
-- Gabor
azfarhussain
Thank you so very much. :)
