halil1
ODT usage for Spartan6 FPGA
I went through SP605, SP601 and Avnet Spartan 6 LX150T Development Board reference designs and saw that external 50 ohm terminations are used on address pins of DDR devices (SP605, SP601). I Avnet Spartan 6 LX150T Development Board no external terminations are used. Is there a problem with ODT usage fro Spartan6 devices?
Thanks in advance
eteam00
Professor
Professor
This is correct design practice.
I suspect you are mistaken about the Avnet S-6 LX150T board design having no terminations for the DRAM address signals.
In DDR2 or DDR3, there is no ODT (on-die-termination) for the address/command group of signals.  Standard practice for these signals is 50-ohm parallel termination to VTT (0.9V termination supply for 1.8V DDR2, 0.75V for 1.5V DDR3).
ODT is only for the byte lane signals:
  • DQ
  • DQS diff pair
  • DM
I suspect not.
-- Bob Elkind
SIGNATURE:
Summary:
