PL DDR memory tests on ZCU106 fail
I created an example design with Vivado 2018.3.  I selected Configurable Zynq UltraScale+ MPSoc Design, then choose a default board ZCU106.zynq_ultra_mpsoc_example.png
After write_bitstream completed, I created an templates application “memory tests” with SDK. The ZCU106 board have not run properly, even the LED INIT_B was still red.
I created an templates application “Hello World” with SDK, the ZCU106 board printed “Hello World” very well. I used an ila to check the c0_init_calib_complete signal, it was high.
Anybody could tell me what’s wrong of this board, or the Vivado have some bug there?
I've found the reason. The psu0_ram could not run  .elf file, so it need placed in the DDR space.
Mentor watari
Mentor
Re: PL DDR memory tests on ZCU106 fail
Hi @wbyjerry
I guess the following URL is helpful for you.
Would you refer it ?
AR #71961
https://www.xilinx.com/support/answers/71961.html
Best regards,
Mentor watari
Mentor
Hi @wbyjerry
AR #71961
Best regards,
