PL-Side SoDimm recommendations for ZCU104 dev-kit
Dear Forum,
I am looking to purchase a ZCU104 dev-kit. Does anyone know the largest capacity SoDimm that can be fitted to this card?
I would clearly prefer a SoDimm that's present as a default option in the Vivado MiG, but an initial indication as to what it can accept will be a good start.
The Micron MTA8ATF51264HZ-2G6B1 chip that is listed in UG1267 is obsolete and I'm working to source an alternative, but I'd like to know if a higher capacity SoDimm can be used on this kit.
DJE666
Re: PL-Side SoDimm recommendations for ZCU104 dev-kit
Hi @dje666,
If you open the link below, you can find the support for the DDR4 SDRAM IP on page 16.
https://www.xilinx.com/support/documentation/ip_documentation/ultrascale_memory_ip/v1_4/pg150-ultrascale-memory-ip.pdf
You can also go into Vivado and open the IP for DDR4 SDRAM (MIG) to see which memory parts are loaded into Vivado for the ZCU104 (under the Basic tab). This forum shows an image of Vivado so you can see what the Customize IP screen looks like if you are unfamiliar.
https://forums.xilinx.com/t5/Memory-Interfaces/ZCU104-SODIMM/td-p/855646
This forum also gives some other links and information regarding what the IP can support.
https://forums.xilinx.com/t5/Memory-Interfaces/MIG-DDR4-IP-supported-SODIMM/td-p/911298
Hopefully this helps!
Sincerely,
Courtney
Please don’t forget to reply, give kudos, and accept as a solution if you found this helpful!
