vamshig51
Passing Heap Size as linker option
Dear Team,
I am working on ZC702, I am trying to pass the HEAP_SIZE while linking the objects, using the below option
-defsym _HEAP_SIZE=0x400000
I am seeing the below error
arm-none-eabi-gcc.exe: error: _HEAP_SIZE=0x400000: No such file or directory
Please give inputs.
Thanks & Regards,
Vamshi G.
vamshig51
hi @ericv ,
In my previous run there is a typo in command, provided "HEAP_SIZE" instead of "_HEAP_SIZE", hence the heap-size did not affected.
below is the right way to pass.
-Wl,--defsym=_HEAP_SIZE=value
Vamshi G.
ericv
@vamshig51
defsym has 2 dashes; i.e. --defsym, not -defsym
vamshig51
Hi @ericv ,
Thanks for your response. I have used the option in reference to this doc https://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug1043-embedded-system-tools.pdf, page-17
I have a src folder with following files, test_heap.c, Xilinx.spec, Xilinx_lscript.ld
Below is how I am copiling
arm-none-eabi-gcc -c -o ./test_heap.o -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard -MP -MMD -Wall -Wextra -O0 -g3 ./test_heap.c
Here I am linking
arm-none-eabi-gcc -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard -Wl,-build-id=none -specs=Xilinx.spec --defsym _HEAP_SIZE=0x400000 -Wl,-T -Wl,Xilinx_lscript.ld -Wl,-Map=test_heap.map -o ./test_heap.elf test_heap.o -Wl,--start-group -lgcc -lc -Wl,--end-group
Iam seeing below errors,
arm-none-eabi-gcc: error: _HEAP_SIZE=0x400000: No such file or directory
arm-none-eabi-gcc: error: unrecognized command line option '--defsym'
Please give your inputs.
Thanks & Regards,
Vamshi G.
ericv
@vamshig51
You are using the command line option --defsym with the compiler. To inform the compiler to pass a command line option to the linker you need to put -Wl, before it.
vamshig51
Hi @ericv ,
I tried that, but still the same error
arm-none-eabi-gcc -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard -Wl,-build-id=none -specs=Xilinx.spec -Wl, --defsym _HEAP_SIZE=0x40000 -Wl,-T -Wl,Xilinx_lscript.ld -Wl,-Map=test_heap.map -o ./test_heap.elf test_heap.o -Wl,--start-group -lgcc -lc -Wl,--end-group
arm-none-eabi-gcc: error: _HEAP_SIZE=0x40000: No such file or directory
Please provide your inputs.
ericv
@vamshig51
Look carefuly at all the other -Wl, on that command line because yours is constructed differently.
vamshig51
Hi @ericv
I have tried as follows, I am not sure if its valid or not, but able to genreate elf
arm-none-eabi-gcc -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard -Wl,--defsym=HEAP_SIZE=0x40000 -Wl,-build-id=none -specs=Xilinx.spec -Wl,-T -Wl,Xilinx_lscript.ld -Wl,-Map=copro.QSPI.map -o ./test_heap.elf test_heap.o -Wl,--start-group -lgcc -lc -Wl,--end-group
but I do not see the change in HEAP_SIZE.
If you know whats the right way please help me providing the command.
Vamshi G.
ericv
@vamshig51
Look in the GCC linker reference manual and you will find the exact syntax for --defsym:
https://ftp.gnu.org/old-gnu/Manuals/ld-2.9.1/html_mono/ld.html
There is a space required and with -Wl, use by the compiler you can pass a space to the linker by replacing it with a comma.
vamshig51
hi @ericv ,
Vamshi G.
