Observer mostafa@sint
Pin assignment for 600 MHz clock on Kintex Ultrascale
Hi All,
I am working with Kintex KCU105 development board.
For a project we need to have 600 MHz clock input and also 600 MHz output both of them are LVDS.
I know that for the input clock we have some specific pins, so I connect it to FMC_LPC_DP0_M2C_P and pin Y2 on the FPGA  that is MGTHRXP0_226.
But for the output clock I dont know that I have to  assign a specific pairs of pin to it or and IO can be used.
Could anyone guide me in this issue?
Re: Pin assignment for 600 MHz clock on Kintex Ultrascale
Hi mostafa@sint
GPIO can be used to forward the clock out from the FPGA.
Restriction only exist on clock inputs, Make sure that clock capable (DBC, QBC, GC) pins are used to bring the clock onto the device.
forwarding the clock
Please refer to the elaborate answer by @avrumw in the similar post
https://forums.xilinx.com/t5/Other-FPGA-Architectures/Clock-capable-pin-pair-as-input-and-output/m-p/900031#M29716
Hi mostafa@sint
Historian
Historian
Why did you choose this pair? Not only is this not a clock capable pair, it isn't even a "regular" I/O pair - it is the RX pair of one of the GTH channels. There is no way (at all) of using this as a clock.
If you want to use a signal as a general purpose clock, it needs to be on a GC pair (from the internal FPGA naming). If you are looking for one on the FMC card, use something like FMC_HPC_LA01_CC_P/N (the FMC name uses _CC_, which was the notation used in the 7 series) - pins G9 and F9.
Avrum
Thanks for your note,
But GTH Rx has more frequency capabilities why we cant use it as a clock source?
Historian
Historian
You just can't. The RX input of the GTH is a dedicated pin that goes only to the GTH receiver, which does clock/data recovery on the signal using the infrastructure of the GTH (including the QPLL/CPLL and dedicated REFCLK of the GTH), ultimately generating a parallel (deserialized) output to the fabric. There is simply no way to route a signal from this pin into the fabric (at all) - forget about accessing the dedicated clocking resource in the FPGA.
Avrum
