Visitor nahir
Pin placement on the VC709 kit
Hi Folks,
  I'm new to all of this, so sorry for the newbee question (I did search for an answer, but did not find).
 I recently purchased a Virtex -7 FPGA VC709 Connectivity Kit.
 I've successfully set up the Vivado IDE, brought up a project etc., but the bitstream generation fails on pin placement (namely, I haven't defined anything).
  All I have is a piece of VHDL that I want to run, drive a clock into, and see the output (in a way similar to what ChipScope provides).
  Can someone assist?
  - Where can I find the list of pins for this board?
  - How do I define the placement?
Thanks!!
  Amir
Re: Pin placement on the VC709 kit
You can find all the kit related documents here, XTP213 section gives you schematic, XDC.
You can define the placements following UG903
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug903-vivado-using-constraints.pdf
Hope this helps
Vanitha
Hope this helps
Vanitha
The exact pin location that is used on VC709 is available in the Appendix
For XDC refer page 71 of http://www.xilinx.com/support/documentation/boards_and_kits/vc709/ug887-vc709-eval-board-v7-fpga.pdf
Hem
